It’s your last hurrah for April! How’s your month so far? Perhaps you’ve done some spring cleaning already or visited a lot of beaches? For sure. However, you might also be one of those taking advantage of the hot weather to try various restaurant foods at home and shop online. If you’re using Postmates, here are the last coupons and discounts for the month of April:
CouponFollow
- Save $20 on Your Purchase: The voucher code MUSTANGS20 can save you up to $20 on your purchases. Make sure to redeem the code upon checkout.
- Postmates Discount Code: Save $20 on Your First Order $25+: Use the coupon code eats-ov16z9329x to save as much as $20 on your very first order, but the value of your purchase must be at least $25. Terms and conditions apply.
- Get $30 Off Your Purchase: Things only get better on Postmates. Slash as much as $30 off your purchase when you redeem the voucher code SAVINGS. Valid for a limited time only.
RetailMeNot
- Up to $40 Off Your Order: Let’s start big. Apply the coupon code on RetailMeNot upon checkout to take $40 off your order. Aside from the conditions, this offer may be limited to select items or locations. Make sure to double-check.
- $30 Off Purchase: Don’t miss this offer, where you can get as much as $30 off your purchase. Simply use the voucher code SAVINGS to get this promo. What are you waiting for?
- $10 off your order: Nothing is too small when you’ve got coupons from RetailMeNot. Redeem the voucher code RACHEF1683 for a $10 discount.
WorthEPenny
- Shop Your Favorites At Up To 50% Off, Right Here At Postmates: At Postmates, you gotta go big or go home. Redeem the coupon code 5MED20 to get as much as 50 percent off your purchases! That’s right, 50 percent off. Let’s go!
- Save Up To 40% On Your Order Applying This Postmates Promo Code: This voucher is a certified WorthEPenny staff pick. Redeem the code indicated on the website to save as much as 40 percent on your order.
- Apply This Postmates Offer To Your Order And Get Up To $25 Off: Use this voucher code, EATS-EGSLCAZR9G, to grab as much as $25 off your order only at Postmates and WorthEPenny. Valid for a limited time only.
SimplyCodes
- 15% Off: We’ve got a new friend, and that’s Simply Codes. The coupon code is easy to remember - DISCOUNT. And you get as much as 15% off your purchase. Amazing, right?
- $20 Off: The discount only gets bigger and bigger. With the voucher code NEWMATES, you can get as much as $20 off. Let’s redeem it!
- $25 Off: Last but certainly not least is this coupon, which gives you as much as $25 off your purchases. Make sure to get the code right. It is AFFEATS25JUL.
You can see that some of those codes may extend until June. That’s better. Shop now on Postmates!
