Every Driver’s Guide On How To Stay Safe Delivering Outside In Spring, Filed By Amazon Flex
Sunburns in summer, and frostbites in winter. No matter as to whether you are wearing protective clothing that guards every inch of you from the harshness of each season, staying safe while on the road is still a must.
Also, it doesn’t mean that it’s springtime that weather is a bit tame. Some of the most common springtime illnesses to face are asthma, allergies, common cold, and Lyme disease, Cleveland Clinic pointed out.
“Early onset of spring and pollen release is associated with increased risk of asthma hospitalization, and increased pollen allergenicity is associated with more severe symptoms…” ScienceDirect told Ridesharing Forum.
Claim it? Leave it. Here are Amazon Flex’s guidelines on how to stay safe delivering outside with Flex during springtime.
Springtime brings heavy winds
March – the start of the spring season – are the windiest months in cities across the USA. This is because strong winds and gusts are often ushered in or brought in by storm systems in the country.
Gusty winds are the teammates of these spring storms, so watch very closely. Even if you adjust the time on your watch, winds are winds.
Tornado threats peak during spring
Don’t feel sad when the Ridesharing Forum team says that tornadoes are common during spring. So, that’s why. Well, it sounds ironic, but this has a long history.
In these times, move to a safe shelter immediately in the nearest establishments you can find. People around will, of course, understand. Then, stay away from windows, doors, and outside walls.
Never, ever try to outrun a tornado in your car. If you are inside a car or outdoors and can’t get to a building, cover your head and neck with your arms and cover your body using a coat or blanket, if possible.
Avoid going under bridges, and watch out for flying debris. The latter can cause death or injury.
Wear protective outfits
Save yourself from springtime weather mess! Wear protective clothing that include breathable and, get this, moisture-wicking materials as inner layers to stay dry, a wind-resistant or waterproof outer jacket, high-quality raincoats with pants and waterproof boots, bright or reflective clothing, sunscreen, and bring allergy medications.
Before ending this talk, your first-aid kit must have the following:
  • Non-latex gloves
  • An assortment of adhesive bandages
  • Antibiotic ointment
  • Sterile gauze pads in assorted sizes
  • Absorbent compress dressings
  • Tweezers
  • Scissors
  • Adhesive cloth tape
  • Aspirin packets (81 mg each)
  • A first aid instruction booklet
For more delivery news, sign up for your account Ridesharing Forum today. Then, join the discussions!
